Changing from W7 Home to Pro
- Changing from W7 Home to Pro
12-04-2012 10:08 AM
Can I Simply go to the Anytime Upgrade and enter the relevant already purchased Key for Pro or would it be advisable to reinstall from scratch?
Forum Moderator and Customer
Re: Changing from W7 Home to Pro
12-04-2012 10:58 AM
If it's an old install then it might be carrying a lot of baggage so a clean install would likely be better.
As yours sounds like a new install I'd go with the key change.
I don't think I actually used 'anytime upgrade', if you already have a new valid key, just enter it via 'control panel', 'system', near the bottom of the screen is 'windows activation' with a link to enter a new product key.
12-04-2012 11:27 AM
Sorting SWMBO's PC at present and will get onto mine later.
13-04-2012 12:44 AM
