Changing WPA key on Thomson 585v7 Wireless Router
bulb
Sorry if this seems a bit novice but im totally new to wireless networks
1. How do i change my WPA key to something stronger and how often should i change it?
2. Is the Thomson 585v7 WPA encrypion 64, 128, 256 or 504bit?
ive found a WPA key generator at http://www.broadbandchoices.co.uk/partner-lp_wireless-key-generator/wireless-key-generator.html#Gene...
Thanks a lot for any replies
MuppetGrinder
Re: Changing WPA key on Thomson 585v7 Wireless Router
I had a spot of bother finding that one as well, you need to open up the wirless network from the menu on the left and then hit the tiny configure link in the top right to get to where you set the security and stuff.  You can choose what level of encryption it uses as well as the type.  if no one fills in more details I'll cover all the basses once I get back in the house and can access my routers admin.
I would have to recomend against using random wpa key generators, you are much better off using a phrase you can remember and switching in special characters for some of the letters.  wpa is strong enough that BruteForce attacks aint worth it, so there is no need for anything as cryptic as a random key (just don't go making it your name or anything like that).  That said there is no need to use random keys for wep either, since the back door on that one is wide enough to walk an elephant through and anyone with half a mind can get access to your network with next to no effort at all, regardless of how cryptic you make your key.
bulb
Thanks a lot
youre help is appreciated.
I've set up two of these routers and in both cases they were preconfigured to WPA-PSK and the key was also preset (it was provided on a note within the box that the router came in).
It seemed reasonably strong to me in that it contained random letters and numbers so I left it as it was. Don't know if this was correct, however.
VileReynard
Seasoned Pro
Fixes: 10
Since the code is printed on the bottom of the router, it's fairly easy to crack!
BTW I'd like to know why "Administrator" is only allowed limited functionality on this model of router.  Sad Sad
MuppetGrinder
Wierd, Admin and User give full access Crazy
MuppetGrinder
OK, here we go, the long version.
First, we log into the router using an administrator level account and select "Home Network" from the left hand side
Now click on the link under Wirless, next to the Pylon type thing.
You are now on the screen with the evasive "configure" link in the top right corner tucked between Details and Help, click this and your where you want to be.
There, that should cover all the bases.
VileReynard
Seasoned Pro
Fixes: 10
Here is the very long bit  Smiley
Try Telnet to the router,
mlp role list
Role                 Parent               Description
Administrator        TechnicalSupport    Any service and any access from LAN/Local origin only
LAN_Admin            Administrator        Only LAN related configurations from any Channel/Origin
PowerUser            Administrator        GUI(Service/overview page)via http/https from LAN origin
root                -                    The superuser
SuperUser            root                Any service and any access from LAN/WAN/LOCAL
TechnicalSupport    SuperUser            Any service and any channels from WAN
User                PowerUser            GUI(Overview pages, remote assistance) via HTTP/HTTPS from LAN
WAN_Admin            Administrator        Only WAN related configurations from any Channels/Origin
mlp privilege list
Privilege            type      Description
anyaccess            access    All access privileges granted
anyservice          service  All service privileges granted
AP1                  access    LAN_Local_all
AP2                  access    LAN_Local with all secured channels
AP3                  access    WAN from a secure HTTP
AP4                  access    LAN from all channels except telnet
AP5                  access    LAN from all secured channels except telnet
AP6                  access    All origins_noHTTP
AP7                  access    All origins_from all secured channels no http
AP8                  access    WAN from all channels
AP9                  access    LAN from a HTTP/HTTPS
SP1                  service  Limited_Read
SP10                service  Simple_network_debugging
SP11                service  Advance_Network_debugging
SP12                service  User_admin
SP13                service  MLP_Admin
SP14                service  Backup & Restore
SP15                service  CLI mngt Interface only
SP16                service  CGI mngt Interface only
SP17                service  FTP mngt Interface only
SP18                service  reset to factory defaults
SP19                service  advance cgi
SP2                  service  detailed_Read
SP3                  service  Write_to_LAN
SP4                  service  Write_FWD_RT_normal_FW_cfgs
SP5                  service  cooperative_cfgs
SP6                  service  Remote Configurations
SP7                  service  Advanced sink & source FW
SP8                  service  Write_to_U_Connection
SP9                  service  Write_to_Local
So what's all this about?
Seems like the WAN side has more privileges than poor old Administrator.
I don't fancy doing the root reset procedure on the router.
I might get locked out by all that security.  Cry Cry
MuppetGrinder
I'm sure I'll get jumped all over if i'm wrong about this, but that looks right for the facilities that the router offer.  Remember PN were such huge fans of these things because it let them play about with the router and get information withought them having to "bother" us.  I'm fairly sure that the "any service" relaits mainly, although probably not exclusivly, to diagnostic reports and procedures that would be of little use to your average end user, but can help PN Tech Support diagnose what's up easier.  Although I don't agree with the fact that we don't get access to it at all.  I think that there should be the inclusion for those who do know, and have enough savie not to bugger things up to be abble to access the features as well.
VileReynard
Seasoned Pro
Fixes: 10
I believe Thomson applied all this security to stop programs like DMT from working properly.
I don't know their name but I've seen allusions that this was due to complaints from a
"British ISP" - the name is never mentioned.
I hope PlusNet are innocent.  Cheesy
MuppetGrinder
I would have to assume that they are, since I signed up just as they were getting the tommie's in (hence why they botched sending me my router, the system didn't catch all the pending deliveries) and when I spoke to the guys at tech support the day it finaly arrived, they didn't have a clue about how they worked Grin All they knew was that in certain circumstances these routers were supposedly going to make there life easier.  Not realy the information I was looking for when I phoned them up to ask the very same question that the OP asked in this thread Grin Grin
To comment though, the guy I spoke to did take time out and played with the router, then called me back about an hour later with the answer to my question.  So absoloutly no fault with the service, find me another company who would do that for you, sure as fuck not BT anyways Wink
VileReynard
Seasoned Pro
Fixes: 10
Quote from: MuppetGrinder
Actually, I've just gone into that configure screen and discovered that the wireless channel was set to automatic (for me it had chosen channel 11).
Since nobody nearby uses channel 1, I changed the auto to manual and chose channel 1.
Result!
Improved wireless performance!!!!  Cheesy Cheesy Cheesy Cheesy
MuppetGrinder
sweet Grin
