Changing SSID and Password on WIFI Thomson TG585
shutter
Fixes: 64
I have reset my Thomson TG585 wireless router, to manufacturers settings, , and my internet access is showing the Plusnet i.d. on Inssider  and also the access password has changed back to default....
How do I change the SSID showing... and the wifi access password ( ideally back to the one I used before resetting the router )...
2 REPLIES 2
Oldjim
Resting Legend
Fixes: 63
Re: Changing SSID and Password on WIFI Thomson TG585
http://192.168.1.254/cgi/b/lan/?be=0&l0=4&l1=-1 then click on WLAN etc. then configure
shutter
Fixes: 64
Thanks Jim....
It`s been so long since I originally set it up.. I forgot everything !...
Been a bit of a struggle, but have made notes to file away..... ( will need some help to find the notes..... so don`t forget where I put them, will you ! !  Roll_eyes )
