Change of networking icons.
FIXED- Subscribe to RSS Feed
- Change of networking icons.
03-06-2016 10:40 PM
Hi all
Normally my wireless internet icon near the clock is a little monitor. The same for my ethernet.
If I disconnect either, I get a little yellow exclamation mark there over the monitor.
Today my wireless icon has changed to a set of bars - like on a mobile phone and my ethernet remains the same.. but it has gained a little red cross... even though it's connected:
I have automatic updates turned off.
Any ideas?
7up.
Fixed! Go to the fix.
07-06-2016 11:55 AM
I wonder if for some reason Windows has decided to create a new network? It's worth checking the network and sharing centre (in control panel) and seeing whether there is more than one network showing.
Re: Change of networking icons.
07-06-2016 7:37 PM
Ahhhhhh
Chris, legend.
I had setup the windows vpn server on my computer the same day as posting that... never thought that would change the icons! Just deleted that from the network and sharing and the icons are normal again.
08-06-2016 9:06 AM
Same kind of thing happened to me previously, so it rang a bell when you posted! Glad that it was as easy at that to sound.
Don't forget to mark it as a fix
