OK so got an android box for the car to replace the standard head unit. Everything works including reverse camera and gps. But it only has one usb socket coming out the back, does anyone have experience in using a hub with these?
I want to connect a USB DAB and a usb 3g dongle to it. I know I will need a powered hub as they both need power from the unit.
I can't see any reason why it wouldn't work but thought I would ask.
Suck it and see is always a possibility, but wondered if anyone had done anything similar.
