Car Tax Licensing using Firefox 3.6.2
- Car Tax Licensing using Firefox 3.6.2
01-04-2010 2:00 PM
When I go to this site http://www.taxdisc.direct.gov.uk clicking on the menu at the side gives the response "page timed out"
It works fine in IE8 and I haven't blocked cookies.
Any suggestions
Any suggestions
7 REPLIES 7
Re: Car Tax Licensing using Firefox
01-04-2010 2:03 PM
ff version 3.5.5 loads ok on this PO connection
updated to 3.5.8 and still ok
01-04-2010 2:08 PM
Using 3.6.2 - should have said so before
Re: Car Tax Licensing using Firefox 3.6.2
01-04-2010 2:29 PM
I have had timeout problems using that website for the previous couple of years.
I think it a slightly over zealous security measure, where it forces a timeout if you don't complete the current action within a very short time frame - which is a nuisance when you are looking through paperwork to find the information it wants, or take slightly too long checking the details on the credit card confirmation page !.
I have seen this on both Windows and Linux both running various versions of Firefox.
So now knowing that this has been a problem, I make sure I have all the info required to hand, and make sure I don't get interrupted when using this site !.
01-04-2010 2:35 PM
No issues in Chrome or FF3.6 here
01-04-2010 3:05 PM
I had time outs but if I chose return to home page and then visited it again it was fine. (Using their menu rather than going direct)
01-04-2010 5:59 PM
Using 3.6.2 and it works fine for me....
01-04-2010 6:04 PM
FF 3.5.8 works fine - perhaps you need to get Linux?
