Cant log into to MSN Live Messenger - is it blocked?
- Re: Cant log into to MSN Live Messenger - is it bl...
18-12-2011 10:58 AM
A couple of weeks ago I started having problems with logging into MSN Live Messenger, it would work after maybe a couple of attempts. BUT - messages I sent to people often didn't get through. Now, I can't log in at all - if I click more information I get taken to a microsoft error page with Error 8100030d. Im on XP SP3, MSN version 2009 (14.0.8117.416)
I thought it was a problem with my PC so uninstalled and reinstalled, but the problem persists. However I also tried it on my old desktop PC, and that won't connect either, so i'm thinking its a problem with the router or maybe its being blocked. I have a Netgear DG834G V2 with firmware V3.01.38.
3 REPLIES 3
Re: Cant log into to MSN Live Messenger - is it blocked?
18-12-2011 1:09 PM
Windows Live Messenger works for me using a TG595v8 and Windows Vista. Since the problem occurs on two PCs I think a router problem is the most likely cause. Does the router allow PnP connections?
David
18-12-2011 3:28 PM
Quote from: spraxyt Does the router allow PnP connections?
Im not sure what that is lol
It seems quite a few people are having this problem http://windowslivehelp.com/thread.aspx?threadid=9af33aa9-d9a2-443c-aa4b-0727f835271c Might be a microsoft problem
adie:green removed bit of quote that wasn't required
18-12-2011 8:23 PM
Other thing to do is to try and reduce the MTU to 1430, sometimes MS sites struggle with it set at 1500.
