Cant get into msconfig on win 7 32bit
- Re: Cant get into msconfig on win 7 32bit
13-06-2013 6:46 PM
Whenever I try to run msconfig I get an error
"There was a problem starting c:\PROGRA~2\codofo6z.dat"
obviouslta file is missing or corrupt
Can anyone help me get it back
4 REPLIES 4
20-06-2013 8:18 AM
More likely you have a virus that is blocking msconfig to stop you using it to disable the virus.
21-06-2013 6:49 PM
Have you tried browsing to C:\Windows\System32 directly and trying to run msconfig.exe?
21-06-2013 8:50 PM
Have a look here - http://forums.moneysavingexpert.com/showthread.php?t=4652605
Does that help?
Does that help?
24-06-2013 8:16 AM
Well that link is to a more comprehensive version of what I wrote; namely that a virus is the root cause of this problem.
