Canon TS6151 printer: any experts to the fore. Please!
Luzern
Seasoned Champion
Fixes: 5
I've been trying without any success to print a 6x4" photo using the printer's rear tray.
The paper is in the carrier as per this.
The instructions were to register the printer on the touch screen, but I can't find the relative section, yet when I go print, the correct settings are there.
The little flap is closed and the carrier in the extended position. I'm guessing the carrier has to be lowered, but do not seem to succeed, because on attempting to lower it the paper remains high up, not moving down with the carrier, nor does the carrier want to close completely.
Hope some kind soul can help!
I try to avoid help desks, as often they know less than I.:wink:
4 REPLIES 4
Gel
Seasoned Pro
Fixes: 17
Re: Canon TS6151 printer: any experts to the fore. Please!
My current Canon no longer has the rear tray, but I've had models in past where I've used
rear tray for photo printing. Where is the touch screen you're referred to?
When you try to print from rear, have you selected that as paper source?
Try Cntrl & P command if you're using Windows and that'll bring up printer
pop up, where you can select paper tray, print quality etc.
Fixes: 27
Luzern
Seasoned Champion
Fixes: 5
Don eall that!:grin: Here's a pic with touch screencanon_pixma_ts6150_review.jpg
Luzern
Seasoned Champion
Fixes: 5
@shutter I think I may have spotted something in link #2
