Canon MP150 and Vista
mossgrove
I am running a Canon MP150 multi function printer / scanner with Vista (SP1).  I have installed the latest driver from Canon.  Everything is fine so long as I start the PC with the printer switched off and then power on the printer.  I can then print a single document, after which the printer seems to insert random page throws, and to corrupt the print buffer - strange multicolour stripes in a monochrome document.  Does anyone else recognise this problem?  I am not sure whether the printer is developing a fault, or if there is an issue with the Vista driver.  (I don't have the option to try the printer on another machine.)
Tim
