Can't watch anything anymore
- Can't watch anything anymore
Re: Can't watch anything anymore
07-09-2009 1:34 PM
I checked out many forums as this appears to be a fairly widespread problem. Some people seem to think that reverting back to Flash9 helped, but it did not help in my case. Most people are stumped. I then found this: http://www.dslreports.com/forum/r19816584-CPU-at-100-when-using-streaming-window. Nobody seems to know the cause but someone found a nice little piece of software called Process Lasso, which helps balance CPU usage across a system. I tried it and it certainly helps, although it is fairly complex so I am not certain I configured it properly. The improvement for me is fairly limited.
I think that the most likely explanation is that my graphics card, while not being inadequate as such, has now deteriorated and would need to be replaced for the particular process of streaming videos.
In the meantime, a vertical dotted line has appeared across my laptop screen. It shows even before Windows starts booting. It does not show when I connect my laptop to my desktop screen. So it looks like my LCD screen is giving up the ghost too.
Not great news for me, but we've had a good five years of use out of it, and it is still useable for other things at the moment... It may be time to start thinking about a new purchase...
07-09-2009 3:54 PM
07-09-2009 6:59 PM
Downloads are not any better on the BBCIPlayer Desktop, with both IE and Firefox closed down.
DVDs and clips in .avi format still do well, though.
07-09-2009 7:19 PM
You would need Quicktime to play these. http://www.apple.com/quicktime/
I honestly think that it's Windows that's causing your problems by not installing codecs as required.
07-09-2009 7:25 PM
07-09-2009 8:12 PM
Is it Ubuntu Desktop Edition 9.04?
The only sad thing is that even Linux won't repair my screen!
07-09-2009 8:28 PM
Sadly when screens start to go it can be expensive. Sometimes though the display problems are caused by the failing of the screen cable which is fed up to the screen through the hinges. I would install the Ubuntu and see what happens first.
If you need help post back. One of the community penguins will be able to assist.
07-09-2009 9:17 PM
Quote from: BlueRhizome Well, why not, sounds like the ideal time to try something new! The laptop is empty.
Yes - give it a try - you don't even have to install it - you can get it to run (slowly) directly from CD.
07-09-2009 9:57 PM
08-09-2009 11:30 AM
08-09-2009 11:45 AM
If Ubuntu wants an add-on or codec, it should offer to install it for you.
In Firefox, select Tools, Addons and under plugins you will hopefully see (some of) what I have loaded (see attachment).
I'm running Ubuntu 9.04 (a 64 bit version) but should be identical otherwise.
BTW You shouldn't/don't install things by downloading.
See System, Administration, Synaptic Package Manager.
This gives you about 20,000 packages you could install - use the "Search icon" to select what you want.
08-09-2009 12:01 PM
08-09-2009 12:27 PM
However, it seems that Helix is pretty important.
So use Synaptic to install both Helix packages.
(If you have difficulties using it, post here!)
08-09-2009 1:12 PM
08-09-2009 2:01 PM
Which sounds like screen related problems are ruled out.
For iPlayer you can download - indeed the downloads are free of the 7 day time limit and of a higher quality than flash
Read http://linuxcentre.net/getiplayer/installation/ for the packages you need to have installed.
Use the aptitude thing to load them, as before.
To install iPlayer as a user program, from Applications, Accessories, Terminal:-
wget http://linuxcentre.net/get_iplayer/get_iplayer
chmod 755 get_iplayer
(This downloads the iPlayer into your home directory).
You may prefer to use the "Linux deb Package (Ubuntu/Debian)" method - but this probably more complicated at this stage.
To run it from the terminal,
I suggest you enter
./get_iplayer -h > get_iplayer.readmeThis will give you a file you can view to see a summary of the numerous parameters.
Assuming you have found the file browser (Nautilus or Dolphin), double-click on get_iplayer.readme to view.
To download a program, enter into the Terminal something like
./get_iplayer -l "News"
This will list a load of numbers and titles.
To Download
./get_iplayer -g 99999where 9999 is your chosen program.
A lot more sophisticated options are available....
This works best with the BBC - but downloads can be 100-200MBytes.
To stop at any point, use CTRL-C.
