Can't view particular site
jft
I cant view some sites on this pc but can on pc at local library any ideas
20 REPLIES 20
rongtw
Fixes: 12
Re: Can't view particular site
which site ?Huh
jft
on safeguard under blocked sites there are several categories  listed and at end of each in grey box the word block does this mean they are blocked by default the site stockingshq/forums is accesible on a public  libraryy pc i.e not site problem
Mav
Fixes: 512
Moderator's note:
I have removed a post that contained some inappropriate material for a family-friendly forum.
Forum Moderator and Customer
rongtw
Fixes: 12
the answer is to turn off safeguard
then install some free software to block sites that you wish to
jft
Safeguard is off
Pete11
Seasoned Pro
Fixes: 4
Just viewed that site and no problems here. Running Hub1, Win7 Home Premium, Google Chrome.
Have you anything blocked by Adblocker or similar prog?
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
jft
ports blocked where  it just stopped working without obvious changes being made any where always been same router
jft
what do you mean
jft
i am on windows 10 and asus dsl-ac68u router and cant view can it be anything in router settings but then it did work and without making any changes it now doesnt
30FTTC06
Fixes: 4
Works ok here.
MauriceC
Fixes: 17
If it's the site you refer to in post #3 then it works fine from here.  It must be something on your PC blocking the site.  Best of luck?
jft
any idea if its something on my pc what it could be or how to find out what it is? ideas?
30FTTC06
Fixes: 4
Banned ?
30FTTC06
Fixes: 4
Try tor
