Can't play youtube vids on Ipad 2 ios7 Through BB
30FTTC06
Fixes: 4
Just looking for a bit of wisdom really, every android device/pc we have weather it be Linux or Windows will play youtube videos through a bullitin board, except for the Ipad 2 Running ios7, it could more than likely be an Unbound configuration issue but i'm not convinced of that yet though. The only difference i'm aware of is HTML.5 Vs Flash.
11 REPLIES 11
Re: Can't play youtube vids on Ipad 2 ios7 Through BB
30FTTC06
Fixes: 4
Many thanks purleigh, i'll have a mooch  Smiley
30FTTC06
Fixes: 4
Minor bugfix on youtube app that was sitting waiting to be upgraded  Grin
Thanks again  purleigh
edit: Still broken, it worked after i restarted the pad, then shortly after it stopped working.
Is it like Windows Update, where you do an update, and then find that there is an update for the first update ?
30FTTC06
Fixes: 4
Dunno, i don't own it  Smiley
when i catch hold of it i'll take another look.
edit: It doesn't appear so no hmmmmmm
30FTTC06
Fixes: 4
Can somebody please test this BB youtube link with an ipad if you have 1, i just need to know for my sanity that it's nothing to do with my Router or equipment. Sad
http://www.musicbanter.com/reggae-ska/74206-rip-junior-murvin.html
Fixes: 1,482
I've just played both clips OK on an iPad Air
30FTTC06
Fixes: 4
Many thanks dvorak, can i be cheeky and ask if you use the default browser ? We have an ipad2 but can't seem to play any embeded youtube videos since an update from ios6.x to ios7
Done all the normal stuff like uninstall re-install youtube etc, but still no good, i was thinking of trying another browser.
Fixes: 1,482
no, I use Chrome. I'll try it on a iPad 3 in a bit.
Just tried in Safari on the air and it works fine.
Fixes: 1,482
iPad 3 with Safari plays ok too.
30FTTC06
Fixes: 4
Many thanks for the replies again dvorak, I had to pop out. Well the only thing I can put it down to is a configuration or similar with the router. I use a seperate box for my wireless devices, but have already moved that over to the TG582n in the last 10 minutes which gives the same result, so that rules that out. I'll keep digging at this now, it's gone on far to long.
