Can't listen to voicemail on Plustalk
Hi
I had an email to tell me I had a voicemail message on Plustalk (which was surprising since no-one knows the number), however having gone to the portal and tried to listen to it, it doesn't work.  Mediaplayer says it can't read the file type (the message says it's a wav file). Huh
odd
LiamM
Re: Can't listen to voicemail on Plustalk
IIRC (from when I worked at PN) there was a problem raised on this shortly before I left.  You should be able to hear the voicemail by calling 7001 as per the FAQ here.
I may try it.  I don't expect it to be important (as I said, I haven't given anyone the number)
Tried it - thought so, wrong number Cheesy
Called them back to let them know
