Can't get past router to access the internet
- Can't get past router to access the internet
26-01-2015 9:22 PM
I even disconnected the ethernet and installed a usb wireless stick , which I thought had cured the issue, but today is suffering the same as if it was wired. I have a spare power plug and tried that, but that has the same problem.
I haven't changed any settings recently. The only thing that has changed since it last worked is that I removed the standalone TG589v3 and replaced with the Openreach modem and TG582n again. It seems somehow that the pc is blacklisted somewhere, but the 582 is a basic router and I don't think it has the ability to block equipment does it?
Thanks for any insight.
Mark
Re: Can't get past router to access the internet
27-01-2015 8:08 AM
Next time it happens run ipconfig from a cmd window and note the default gateway setting. Post the details here and hopefully we will be able to sort out what's happening...
Quote I can access the router interface from this pc, but cannot get any further.
27-01-2015 1:04 PM
C:\Users\Mark>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lan
Link-local IPv6 Address . . . . . : fe80::e933:9196:34e5:9275%3
IPv4 Address. . . . . . . . . . . : 192.168.1.84
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
Tunnel adapter Local Area Connection* 11:
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:18ea:32bb:6d37:e792
Link-local IPv6 Address . . . . . : fe80::18ea:32bb:6d37:e792%4
Default Gateway . . . . . . . . . : ::
Tunnel adapter isatap.lan:
Media State . . . . . . . . . . . : Media disconnected
27-01-2015 1:05 PM
27-01-2015 1:37 PM
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\Mark>tracert www.plus.net
Tracing route to www.plus.net [198.18.1.47]
over a maximum of 30 hops:
1 6 ms 3 ms 3 ms dsldevice.lan [192.168.1.254]
2 29 ms 28 ms 29 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Users\Mark>tracert www.facebook.com
Tracing route to www.facebook.com [198.18.1.48]
1 4 ms 4 ms 6 ms dsldevice.lan [192.168.1.254]
2 30 ms 31 ms 30 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
Trace complete.
So it appears to be getting to PN, but no further!!
A similar traceroute from the unaffected laptop:
Tracing route to portal.plus.net [212.159.8.2]
1 1 ms 1 ms 1 ms dsldevice.lan [192.168.1.254]
2 27 ms 28 ms 27 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
3 27 ms 27 ms 27 ms irb.10.PTW-CR01.plus.net [84.93.249.1]
4 27 ms 27 ms 27 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
5 33 ms 33 ms 34 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
6 34 ms 35 ms 35 ms po5.peh-cr01.plus.net [84.93.232.16]
7 40 ms 37 ms 34 ms vlan2657.peh-elb01.plus.net [84.93.232.44]
8 34 ms 35 ms 36 ms portal.plus.net [212.159.8.2]
Trace complete.
Tracing route to star.c10r.facebook.com [31.13.90.2]
2 27 ms 26 ms 27 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
3 27 ms 26 ms 27 ms irb.10.PTW-CR02.plus.net [84.93.249.2]
7 27 ms 27 ms 27 ms edge-star-shv-01-lhr3.facebook.com [31.13.90.2]
27-01-2015 1:43 PM
It does to me as well
Quote Now I have access, it looks the same to me
I had hoped that we'd see something change in the gateway and theat might give a clue. Given that you say you still have access to the router then the IP/subnet must be ok and the most likely culprit was the gateway. Although... you might try disabling IPV6 on the router to see if that might the problem see this thread http://community.plus.net/forum/index.php/topic,130654.0.html
27-01-2015 1:59 PM
Mark
27-01-2015 2:05 PM
Failing
Quote Tracing route to www.plus.net [198.18.1.47]
Working
Quote Tracing route to portal.plus.net [212.159.8.2]
27-01-2015 2:10 PM
Mark
27-01-2015 2:50 PM
27-01-2015 3:25 PM
C:\Users\Mark>ipconfig/all
Host Name . . . . . . . . . . . . : TowerPC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : D8-50-E6-C4-6C-09
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.84(Preferred)
Lease Obtained. . . . . . . . . . : 27 January 2015 14:12:59
Lease Expires . . . . . . . . . . : 28 January 2015 14:12:58
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:18ea:32bb:6d37:e792(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::18ea:32bb:6d37:e792%4(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 83886080
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-92-F3-49-D8-50-E6-C4-6C-09
NetBIOS over Tcpip. . . . . . . . : Disabled
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
While the connection wasn't working, I did the traceroute again, with the previous result.
Tracing route to www.plus.net [198.18.1.145]
1 3 ms 4 ms 5 ms dsldevice.lan [192.168.1.254]
2 30 ms 33 ms 29 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
Trace complete.
I then turned off the home plug and back on, then ran a traceroute and it is as normal.
1 4 ms 3 ms 3 ms dsldevice.lan [192.168.1.254]
2 29 ms 31 ms 32 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128
.170]
3 65 ms 29 ms 30 ms irb.10.PTW-CR01.plus.net [84.93.249.1]
4 29 ms 29 ms 29 ms te9-4.ptn-gw01.plus.net [195.166.129.33]
5 * 39 ms 35 ms gi5-1.peh-cr02.plus.net [84.93.232.61]
6 37 ms 35 ms 38 ms po5.peh-cr01.plus.net [84.93.232.16]
7 57 ms 37 ms 37 ms vlan2657.peh-elb01.plus.net [84.93.232.44]
8 36 ms 37 ms 39 ms portal.plus.net [212.159.8.2]
Trace complete.
3 minutes later however, it is reverting back to the strange ip address previously referred to and no access again
27-01-2015 3:32 PM
27-01-2015 3:47 PM
Mark
27-01-2015 5:18 PM
27-01-2015 5:26 PM
I changed to Google dns about an hour ago and have been randomly going back to check. All seems fine for now.
Thanks for your help and for pointing me in the right direction.
Mark
