Can't connect to usergroup IRC
- Can't connect to usergroup IRC
03-06-2010 10:16 PM
Whenever I try and connect to irc://usergroup.plus.net:6667 I'm booted with the following
Can anyone shed some light on this?
Cheers,
A.
Quote [10:12 pm] * Connecting to usergroup.plus.net (6667)
[10:12 pm] -usergroup.plus.net- *** Looking up your hostname...
[10:12 pm] -usergroup.plus.net- *** Checking Ident
[10:12 pm] -usergroup.plus.net- *** Found your hostname
[10:12 pm] Closing Link: powered.by.avatastic.co.uk (Bad user info)
Cheers,
A.
5 REPLIES 5
Re: Can't connect to usergroup IRC
03-06-2010 10:51 PM
Are you trying to connect from a non-PN connection?
Try http://usertools.plus.net/irc/
03-06-2010 10:58 PM
I can connect from the java client.
I'm trying to connect from a PN connection.
I can guess at the problem
its either a) my reverse dns isn't a recognised plusnet one as its set to my own domain or
b) I'm coming from behind a NAT so the IP my client is sending isn't matching the external IP.
06-06-2010 2:45 PM
06-06-2010 2:55 PM
So did it work without the URL then?
06-06-2010 2:58 PM
