Can't connect to usergroup IRC
avatastic
Whenever I try and connect to irc://usergroup.plus.net:6667 I'm booted with the following
[10:12 pm] * Connecting to usergroup.plus.net (6667)
[10:12 pm] -usergroup.plus.net- *** Looking up your hostname...
[10:12 pm] -usergroup.plus.net- *** Checking Ident
[10:12 pm] -usergroup.plus.net- *** Found your hostname
[10:12 pm] Closing Link: powered.by.avatastic.co.uk (Bad user info)
Can anyone shed some light on this?
Cheers,
A.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
5 REPLIES 5
Fixes: 1,483
Re: Can't connect to usergroup IRC
Are you trying to connect from a non-PN connection?
Try http://usertools.plus.net/irc/
avatastic
I can connect from the java client.
I'm trying to connect from a PN connection.
I can guess at the problem
its either a) my reverse dns isn't a recognised plusnet one as its set to my own domain or
b) I'm coming from behind a NAT so the IP my client is sending isn't matching the external IP.
avatastic
or c)
It didn't like that I had a URL in my 'real-name' info.
bobpullen
Fixes: 316
So did it work without the URL then?
avatastic
@Bob yep, I've rolled back the other changes I made to my client and connecting without the URL  still works.
