Can't access anything
southken
My father has a problem with his laptop, the mouse pointer is working ok but when he clicks to access anything, eg, internet, it just won't open it.  I can't close it down and restart it or anything, it is just stuck.  Any ideas, please.
Fixes: 62
Re: Can't access anything
Is he using a touch pad or an external mouse and which make of laptop is it
southken
It is an HP 530 laptop and he is using a touch pad.
VileReynard
Seasoned Pro
Fixes: 11
Plug a mouse in.
Fixes: 62
I would agree with that but then I hate touch pads.
However it may be a driver problem so try loading the latest version from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3375995&lang=en&cc=us...
VileReynard
Seasoned Pro
Fixes: 11
Wouldn't Plug 'n' Pray work?
southken
Thanks for your replies, it is now sorted, i had to go into mouse on the control panel and enable the touchpad function.  He had no idea how it happened, he didn't do anything of course!
