Can anyone recommend.....
Ryan1uk
Hi
Can anyone recommend a good cheap router that can be put in DMZ?
Thankyou
Ryan Smiley
2 REPLIES 2
VileReynard
Fixes: 20
Re: Can anyone recommend.....
Assuming you want [Wikipedia]
DMZ host
Some home routers refer to a DMZ host. A home router DMZ host is a host on the internal network that has all ports exposed, except those ports otherwise forwarded. By definition this is not a true DMZ (Demilitarized Zone), since it alone does not separate the host from the internal network. That is, the DMZ host is able to connect to hosts on the internal network, whereas hosts within a real DMZ are prevented from connecting with the internal network by a firewall that separates them, unless the firewall permits the connection. A firewall may allow this if a host on the internal network first requests a connection to the host within the DMZ. The DMZ host provides none of the security advantages that a subnet provides and is often used as an easy method of forwarding all ports to another firewall / NAT device.
A netgear DG834G can do this - not desperately cheap, but not expensive - but you can't create a real DMZ with it.
Ryan1uk
Thankyou very much  A Fox is Evil  i will get one of them.
Cheers
Ryan
