Can anyone recommend freeware website builder ?
shermans
I have been laboriously writing my own html code for various websites for many years, but after a bit they all tend to look the same !
I need to do something for a charity, and thought I might look for a short-cut.  Can anyone recommend a simple freeware website builder ?
4 REPLIES 4
Fixes: 88
Re: Can anyone recommend freeware website builder ?
Have a look at http://www.kompozer.net/
mystery
HI,
I've put together a professional looking website using 'Ewisoft website builder'. Although it does have a link to the website from your site, it is by far the best I've tried as it is not a web based builder which only allows you to publish on their own servers. You can publish your finished site wherever you like.
The customer support is also very good. I have been talked through things I thought impossible. The link is  http://www.ewisoft.com/
Denzil
Try NVU (pronounced enview), which is related to Kompozer. Free download from www.nvu.com
It also handles website management and uploads.
Openoffice can do WYSIWYG website creation as well, but it is not quite as good as a dedicated application.
Kompozer is a bug-fix version of Nvu.
