Can anyone recommend a freeware Registry Cleaner ?
- Can anyone recommend a freeware Registry Cleaner ?
- « Previous
- 1
- 2
- Next »
Re: Can anyone recommend a freeware Registry Cleaner ?
30-05-2008 6:54 AM
and recently
30-05-2008 9:04 AM
Just been looking at ed 101 of PC Utilities, it claims version 206 of Ccleaner is Vista OK, not got Vista so cant try
its also got Easy cleaner EClear2_o.exe and nCleaner on disc both Vista aware plus several others
31-05-2008 10:52 AM
Ccleaner and Eusing both work fine with Vista. It was the Abexo product that doesn't support Vista.
21-07-2008 10:48 PM
I use CCleaner, but have also installed and used EasyCleaner following a recommendation on Gizmo's excellent advice site which is at http://www.techsupportalert.com/ . His comment was that CCleaner's settings were a bit "aggressive", and that EasyCleaner was equally, or more, effective.
Oh, I'm using Windows XP, so can't comment on whether EasyCleaner works with Vista
br1anstorm
br1anstorm
- « Previous
- 1
- 2
- Next »
