Can anyone recommend a freeware Registry Cleaner ?
- Can anyone recommend a freeware Registry Cleaner ?
19-05-2008 12:38 PM
I suspect that these are scams, frankly. I do not want to throw good money after bad, and businesses which pretend to offer freeware, but who are actually trying to sell their product leave me always suspicious.
I realise that there is no such thing as a free meal, but there is no point in paying £30 for a product which really does no more than the genuine freeware ccleaner.
So can any comment on these various Registry Cleaners ? Do they really offer good value for money or not ? Do they actually do anything more than ccleaner ? Unless there really is going to be a performance difference, (not that I am complaing about my current performance), then I prefer to follow the old saying "If it ain't broke, don't fix it !
Re: Can anyone recommend a freeware Registry Cleaner ?
19-05-2008 12:58 PM
(I'm sure there's a UK site too, but Registry cleaners don't care)
19-05-2008 1:05 PM
CCleaner seems to be good - I would stick with that. You could also try the <a href="http://www.tweaknow.com/RegCleaner.html">Tweaknow RegCleaner</a>. Simpler than CCleaner but quite good at removing orphaned entries.
19-05-2008 1:26 PM
Quote from: HPsauce I use Microsoft's own tool built into the Onecare scanner at http://onecare.live.com/site/en-US/default.htm
HPsauce..... I clicked on your link, to see how/what and then clicked on the "full scan" (I know, I`m greedy) but I got this result
We're sorry. This version of the Windows Live OneCare safety scanner doesn't work with your Web browser or operating system.
You need Windows XP Home Edition, Windows XP Professional, Windows 2000 Professional, Windows Server 2003, or Windows 2000 Server. You also need either Microsoft Internet Explorer 6.0 or MSN® 9.0 or higher.
I am running Windows XP home, and I have IE6, (OE7)
I also clicked on the "individual" scan boxes, same response ! ! !
19-05-2008 1:28 PM
(CCleaner for you then)
19-05-2008 2:23 PM
Thanks for the tip. It seems that this is a Microsoft tool, so presumably should be bona fide. I have downloaded it, and it is now running in the background, scanning and hopefully fixing anything that needs fixing. It tells me it could take up to several hours, but presumably that includes a defrag of the hard disk which hopefully will not need doing as I do that regularly already.
However, one thing puzzles me. Maybe when it has finished it will all become crystal clear. But in case it does not become crystal clear, how do I start it off again next time ? It seemed to download 11 files, but it did not appear to use the usual install process, and there are no links / shortcuts on the Desktop. On the other hand, the name Opencare Live suggests that it is interfacing LIVE with the web while it is scanning, so maybe that has something to do with it. Am I right in thinking that each time I want to start it, I need to use your link http://onecare.live.com/site/en-US/default.htm to start it off ? Does it download those 11 files again each time ?
It looks interesting, so thanks again.
Shutter
You mention IE6. I heard that MS are discontinuing support for IE6 and are forcing everyone to upgrade to IE7. Could this be the cause of your problem ?
19-05-2008 2:45 PM
It installs ActiveX controls in IE and presumably checks/updates them each time; you can see it in the installed programs list via Control Panel.
I use it regularly, but use the "customize" option to choose which options to do. As you say the "full monty" takes ages.
19-05-2008 2:51 PM
I am using OE7 which does not update IE6 apparently, and my IE is IE6 so there should be no problem running the link that HPsauce put up.....
My laptop is ticking all the boxes....
EDIT=======
O.K. so I am the "wally"..... I was using Firefox at the time ! Doh ! !
19-05-2008 7:55 PM
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
19-05-2008 9:08 PM
Thanks guys. This has been very useful. I have run Onecare which took for ever but seemed to be very thorough, and I think that this is the once a month job. I then ran eusing (funny name ?) which found 450 registry errors and cleaned them up, but it only took about five minutes. This will be weekly housekeeping from now on. ccleaner is the quickest but obviously leaves things behind.
I think a combination of all three does no harm. It will be interesting to see if I notice any difference.
So the help has been much appreciated.
19-05-2008 9:59 PM
you have to scratch around their site a bit to find the free version, but it is there, and it does work rather well
paul
19-05-2008 10:26 PM
http://www.abexo.com/free-registry-cleaner.htm
So thanks again. After all this, I must have the cleanest registry in Plusnet ! And, touch wood, everything still works !!!
19-05-2008 10:52 PM
29-05-2008 10:01 PM
29-05-2008 11:09 PM
