Can anyone recomend me ............
- Can anyone recomend me ............
30-09-2015 9:59 PM
A wireless usb stick that i can plug into a computer ?
6 REPLIES 6
Re: Can anyone recomend me ............
30-09-2015 10:00 PM
Nope but I would have suggested a wireless card with a separate aerial
30-09-2015 10:06 PM
If a USB one is what you want I recommend the EdiMax ones which I find very useful setting up new systems.
The version I have is an EW-7711UAn though that may have been superceded.
Comes with a handy little semi-rigid bendable extension cable:
30-09-2015 11:38 PM
HPsauce recommends about the biggest one you can get! That should have excellent range but they do come much smaller if your computer isn't too far from your router.
01-10-2015 10:40 AM
Ill be using this on a pc upstairs, seams pretty cheap
http://www.amazon.co.uk/Edimax-EW-7711UAN-Wireless-nLITE-Adapter/dp/B001KOTDDU/ref=sr_1_6?ie=UTF8&qi...
05-10-2015 1:17 PM
Thanks HPsauce i have it working, works a treat so ive ordered another one for backup
Cheers pal
09-10-2015 9:36 PM
Quote from: St3 A wireless usb stick that i can plug into a computer ?
Well it's been a long time since i saw a usb stick WITH a wire to be honest... most sandisk or kingston usb disks were wireless since the invention of flash memory
