Can anyone recomend me ............
St3
Aspiring Champion
Fixes: 5
A wireless usb stick that i can plug into a computer ?
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Can anyone recomend me ............
Nope but I would have suggested a wireless card with a separate aerial
HPsauce
If a USB one is what you want I recommend the EdiMax ones which I find very useful setting up new systems.
The version I have is an EW-7711UAn though that may have been superceded.
Comes with a handy little semi-rigid bendable extension cable:
ReedRichards
Seasoned Pro
Fixes: 25
HPsauce recommends about the biggest one you can get!  That should have excellent range but they do come much smaller if your computer isn't too far from your router.
St3
Aspiring Champion
Fixes: 5
St3
Aspiring Champion
Fixes: 5
Thanks HPsauce i have it working, works a treat so ive ordered another one for backup Smiley Cheers pal
7up
Fixes: 17
Quote from: St3
Well it's been a long time since i saw a usb stick WITH a wire to be honest... most sandisk or kingston usb disks were wireless since the invention of flash memory  Cheesy
