Can access network but not the internet
- Can access network but not the internet
02-05-2009 2:18 PM
I have an satndard asus 8021 b/g card in my desktop, i powered off the router whilst the pc was still on and now when i boot up my pc i can cooenct to the internet but keep getting limited connectivity message and cannot access the internet through my desktop, both my laptops are fine. Never had this problem with my previous roter only this new thomson one.
I have tried to repiar the network etc on the desktop, removed the desktop from the router and tried reconnecting all but to no avail !!!
Argggg im pulling my hair out - any suggestions.
Re: Can access network but not the internet
02-05-2009 3:06 PM
Is it a DHCP problem?
Can you see your wireless address retained in the router?
Have you configured duplicate static ip addresses on your LAN?
Does it only happen for certain web sites?
If so try ipconfig /flushdns in a command entry screen.
03-05-2009 9:32 AM
Its not for certain websites, it will not get a connection at all to the internet through my desktop, have been reparing eg - renewing ip dns etc but still same problem
03-05-2009 10:56 AM
Its an ASUS WL-138G pci adapter
Looking on the web this seems to be a common problem witgh the asus card and the router - think ill just get a new card
03-05-2009 12:20 PM
Quote from: nibor I see what you mean by DCHP now, DHCP is enabled etc , as my other computers connect no problem and can access the internet. Defoo something to do with my wirelss card and the router communication
I don't quite understand your use of English - but lots of people can't make it work either http://www.fixya.com/support/t236146-problem_wireles_adapter
Since it's a laptop, I suggest you try making a wired (non-wireless!) connection to see if it's a router problem.
03-05-2009 11:08 PM
Sounds to me most likely a faulty wireless card.
04-05-2009 1:08 AM
How about the encryption being wrong - is it WEP or WPA and has it got the right passphrase?
04-05-2009 10:16 AM
11-05-2009 8:43 PM
11-05-2009 10:14 PM
Is it the same make or model as the previous card?
12-05-2009 12:25 PM
12-05-2009 12:49 PM
As you've changed router it could be that the firewall needs to be told to trust the new network.
Try disabling the firewall temporarily and, if that works, you'll need to put your new network into the firewall's trusted zone.
12-05-2009 5:40 PM
12-05-2009 6:08 PM
12-05-2009 6:11 PM
