Can Mac users check this site
Oldjim
Resting Legend
Fixes: 63
http://www.joanscott.co.uk/coastal/index.html
We have received an email which states
FYI: Unable to view your work normally.
I'm only able to see the thumbnails. When  I click on a thumb nail the full size image flickers for just a split  second, but won't stay onscreen.
I'm on a MAC with the latest everything updated.
It works fine in all browsers under Windows
22 REPLIES 22
Fixes: 1,483
Re: Can Mac users check this site
Not at home to try but doesn't work on my phone browser
Be3G
I'm trying it using Safari 4 beta for Mac and I get the same as the sender of the e-mail. Have you actually tried Safari on Windows Jim?
Strat
Fixes: 565
Doesn't work on my iPhone.
Oldjim
Resting Legend
Fixes: 63
Can you try this site which uses a similar coding.http://www.cssplay.co.uk/menu/gallery_click2.html#nogo
If it works I have messed something up
Fixes: 1,483
Nope, doesn't work on the phone browser.
Oldjim
Resting Legend
Fixes: 63
Thanks - now to do a lot more digging  Sad
Be3G
FWIW, I have just noticed that (with both your and the demo sites) the image stays on screen for as long as the mouse button is held down.
pierre_pierre
it doesnt work on my Archos 705 either, not sure what the browser is on that, but OK on Asus linux and firefox
Oldjim
Resting Legend
Fixes: 63
@Be3G
That seems to be a problem with a Mac and the href="#nogo function but I haven't found a reason or a workaround yet
Fixes: 1,483
Jim - just tried it using Firefox 3.10 on OS X and it works OK.
Oldjim
Resting Legend
Fixes: 63
just had a reply
Hi Jim, this is a 'feature' of the Mac mouse. It only registers the mouse click when the button is held down.
MacOS10
Works fine on Camino 1.6 (uses the same engine as Firefox), but doesn't work in Safari 3, like others have said. Looked at the code, and I have to confess it doesn't look like a standard code - not that I'm an expert, just dabble with the coding side really. I don't understand how it's done, but it certainly looks messy to me.
Would this kind of effect not be better achieved by using Javascript to change the images? Dreamweaver has a useful Swap Image behaviour that should do this kind of thing.
BTW: Your other example again works on Camino but doesn't on Safari, so it doesn't appear that you've done anything to the code - it's just that it's not compatible with certain browsers. Safari is one of the most strict browsers on sticking to web standards, which is probably why a lot of the sites "tweaked" to make them work on Internet Explorer on Windows don't always work as expected. The problem is really Internet Explorer, of course, but the trouble is a good percentage of people use it - rightly or wrongly!
MacOS10
Not sure if this helps you, but Dreamweaver's code validation reported these issues that need addressing...
Oldjim
Resting Legend
Fixes: 63
deleted - I answered the question
