Can I use a second router to extend my network?
- Re: Can I use a second router to extend my network...
11-09-2007 10:23 PM
I recently acquired a second wifi router (voyager 2091, courtesy of plusnet) and was wondering if I could use it as a kind of access point to connect to my existing network and extend it's range so the laptop can be used in more of the house. I imagined plugging it in part way between the netgear router and where the connection drops off, and have it pick up the ssid I am on and transmit it to the far reaches of the house. I was wondering A) if this is possible and if so B) what settings do I need to change in order to do it. I presume I need to manually alter the I.P address of the 2nd router so that it is in the range of the 1st one, but do I need to do anything else? I read somewhere about turning off DHCP or something, but am not sure how I do this on the new router.
Also do people with experience of both these routers have any advice on which provides a better signal? Would it be worth just replacing the 2yr old netgear with the voyager?
Any advice would be much appreciated.
Thanks,
Rob
Re: Can I use a second router to extend my network?
11-09-2007 11:01 PM
IIrc its not possible to use two separate wireless routers on one ADSL line as it causes conflicts so what you need is a dedicated access point to sit exactly where you say the signal starts dropping, ive set these up for quite a few people and it works very well covering the whole house instead of just part of it
Can you not extend your phone socket from where it is to a more convenient location, even if its the master socket an extension wont make any difference to line noise unless its very long this is when problems can arise
The DG834G is a very good router and as you say is a couple of years old now but imho you will see no benefit from changing it to something else just make sure it has the latest firmware installed
I remember reading sometime ago about some success being had from modifying the aerial i think with card and foil to make the signal more directional so maybe a google search will uncover this if you want to try the £0 option
11-09-2007 11:07 PM
You could also try one of these.
12-09-2007 9:25 AM
12-09-2007 11:18 PM
You simply set up your main router to connect to the internet then the second router to connect to the preliminary router.
However, one thing I would say is that if you intend on 'buying' a second router. Dont bother. Simply just get a hub or AP to extend your range.
12-09-2007 11:48 PM
I have a reasonable amount of knowledge but simpler would be good!
Do you mesn I can get the second router to connect to the wirelss network of the first and amplify/extend the signal? This is what I am after
13-09-2007 12:06 AM
This initially means that you have to change the login address of it.
I suggest changing it to something like 192.168.1.1 (do this through LAN IP Setup)
Then once you've done that (you can verify this has been correctly done by trying to login on 192.168.1.1) you need to make it connect to the first router (which should be 192.168.0.1) which is normally done through Basic Settings for the router.
Now, bear with me, I have not done this in a while, but I believe you set up the DNS server on the second router as 192.168.0.1
DO NOT enter login details. It should simply sync to your first router and connect to the net that way.
Now, I have no experience with doing this wirelessly. As previously as PJ mentioned I hardwired them.
13-09-2007 12:26 AM
I don't know enough about yours (& I'm not downloading & studying the manuals at this time of night ) but I guess it's unlikely.
I sure you could do it ok if you can run a cable, as suggested, but unlikely otherwise.
The other suggestions made earlier in the thread may be a better option for you if a cable isn't feasible.
13-09-2007 12:48 AM
a wireless card (to connect to the first wireless AP)
an ethernet card to connect to the second (wireless router)
Load "some software to perform the routing functions".
Actually, since I notice that my wireless Netgear ADSL/router uses a severely cut-down version of Linux to do all the clever bits, I assume that you would Linux for this.
BTW I have seen this kind of thing done (years ago) as a bridge between a token-ring network and an ethernet network. There wasn't any NAT, DHCP etc involved though.
13-09-2007 10:38 AM
13-09-2007 2:33 PM
Quote from: docrobster more cables cluttering up the house aren't going to be allowed by the wife.
Maybe you should do a trade & get a new ....
No, no - whatever am I thinking.
Try this blog instead for some other alternatives to more cables. There are Powerline products that will let you extend wireless range this way. Follow the links from the blog.
13-09-2007 5:16 PM
16-09-2007 1:10 PM
I've been using a NetGear DG834GT combined modem/router, connected to the one phone point in my house. For the past two+ years, it's worked fine - I've been able to keep both my laptops connected from my dining room table (same room as the router) and my wife has been connected from upstairs (it's a small house and I'm guessing the distance between her PC and the NetGear unit is less than 40 feet).
Recently, her machine - actually one of my old ones that until four weeks ago was fine - has started dropping it's wireless connection. She is using a Toshiba SatPro 6000 with a built-in wireless card. I suspected that it was her card, so I disabled it and substituted a NetGear MA40x (can't remember the number) PCMCIA wireless card with no real success. I then tried the wireless USB / memory stick that came with the router - no joy there either. I've purchased a further NetGear DG834 unit, updated the drivers and it still doesn't work.
My newer laptops are fine in the same location where the failing machine sits.
In summary, I've switched the router and tried two alternate wireless cards in the failing laptop. I'm therefore reasonably certain that it can't be the router and I find it hard to believe that all three cards - the NetGear PCMCIA card, the USB stick and the built-in card - are all faulty. There has to be something else in this laptop that is causing the problem.
I'm working outside the UK until next weekend, so cannot try the advice regarding linking the two routers together, but I will try that as soon as I can.
Can anyone suggest any other potential resolutions?
Jeremy
16-09-2007 1:53 PM
I'll give NetStumbler a go ASAP.
I've also acquired a DECT headset (used to teach online training classes) which is typically connected as extension #3 in the office/bedroom also ... however, that's been in situ for six months and there weren't any issues until four weeks ago.
Our wireless network is using channel 6 - I guess it could be interference as you suggested and as soon as I get back home next weekend, I'll try switching channels and report back.
Again, my thanks for your prompt suggestion.
18-09-2007 9:38 AM
Re. the other suggestions I may go down the power line networking route- seems to be a good way to extend a network. Has anyone had any "issues" with powerline networks? All the reviews I have read are good so far, I wondered if there are hidden surprises?
One thing that has affected my wifi network is a video sender. I realised there might be an issue when trying to watch TV in the bedroom via the video sender, there was interference that disappeared when the router was unplugged. Consequently I have switched off the video sender and there seems to be less holes in the wifi coverage now.
Now I just have to decide between sky multiroom and a slingbox!
