Can I retrieve mail from Thunderbird on a failed Hard drive
- Can I retrieve mail from Thunderbird on a failed H...
14-03-2010 4:03 PM
I can access the hard drive using a caddy and I have found the mail folder in Thunderbird which contains the inbox, sent, trash, etc
I tried running Mozbackup but cant find a way to guide it to that folder.
Does anyone know another way.?
I cant reinstall the OS (vista) without overwriting and losing all the files
1 REPLY 1
Re: Can I retrieve mail from Thunderbird on a failed Hard drive
14-03-2010 4:20 PM
If you COPY the mail folder on to another drive and change the default profile to point at this that should do it.
