Can Gizmo Project be used with PlusNet's SIP service?
- Can Gizmo Project be used with PlusNet's SIP servi...
04-10-2007 6:07 AM
Does anyone know if Gizmo Project (http://www.gizmoproject.com) can be used with PlusNet's SIP service?
Gizmo Project "allows you to simultaneously log in to your Gizmo account, and another SIP based server. You can then receive in-coming calls through either service, and you can send out-going calls through either service." (taken from http://support.gizmoproject.com/index.php?_a=knowledgebase&_j=questiondetails&_i=188). If PlusNet have a SIP-based server, then I should be able to use Gizmo Project?
1 REPLY 1
Re: Can Gizmo Project be used with PlusNet's SIP service?
04-10-2007 7:44 AM
Plusnet use a product called Asterisk on the server side, which is 100% SIP compliant so I see no reason why it wouldn't work.
B.
EDIT: fixed typo. Thx chilly - brain not in gear
B.
