Calendar program
Mav
Fixes: 504
Calendar program
SWMBO has been looking for a decent calender program that can do reminders for appointments, birthdays, etc and be configurable regarding such things as sounds and so forth.
I found some on Google but having installed, even using the Custom option, installed lots of gunk.
A search in this forum hasn't found anything. She doesn't want anything like Outlook as she doesn't want links to emails. Free would be good but does anyone have any recommendations?
Forum Moderator and Customer
9 REPLIES 9
rongtw
Fixes: 12
Re: Calendar program
Mav . i havent tried it but this looks ok  Cool
http://download.cnet.com/iDailyDiary-Free/3000-2124_4-10211308.html?tag=mncol;1
Nibiru
Fixes: 12
Do any of these look interesting ? -
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.6.0 router, DrayTek WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
Mav
Fixes: 504
Thanks, have passed them on to SWMBO to take a gander.
Pedro
Hi
Don't know how useful this will be since you mention outlook, but I use a Thunderbird add-on called Lightning
It's highly configurable and has all you ask for and more. It does mean you have to install Thunderbird if you don't use it already, but I guess you can use it solely as a calendar program if you have no use for the email client.
Good luck.
Razer
Quote from: Mav
Quote from: Pedro
Hi ...
I'm having a deja vu. Cheesy
ITWorks
Fixes: 8
I find Rainlendar Lite to be very good.
http://www.rainlendar.net/cms/index.php
Regards
Mike
Mav
Fixes: 504
Thanks all.
Have passed all your comments/suggestions to SWMBO.
journeys
bit late, but would suggest google's online calendar
Mav
Fixes: 504
@journeys That was my first suggestion but she doesn't like that idea Sad
