CPU Cooling fan
cbcadmin
CPU Cooling fan
Can anyone confirm the pin outs on a cpu cooling fan please?
2 pin - +5v & ground
3 pin - +5v, +12v & ground
4 pin - +5v, +12v, ground & control/temp sensor
The reason I ask is because I have an HP server that has a 3 pin fan where the motherboard has a 4 pin socket. Two pins appear to be connected together! How would that work?
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
2 REPLIES 2
Fixes: 585
Re: CPU Cooling fan
https://landing.coolermaster.com/faq/how-to-connect-a-3-pin-or-4-pin-fan-to-the-motherboard/
cbcadmin
Re: CPU Cooling fan
Thanks. I am still confused how/why the original fan is a three pin one, but the motherboard and indeed the fan has a four pin connector. I've replaced the fan with a four pin one, but despite spinning up, the motherboard reports a fault.
https://www.aliexpress.com/item/905600342.html?gatewayAdapt=Msite2Pc
