CPU Coolers
- CPU Coolers
CPU Coolers
31-01-2015 7:53 PM
Re: CPU Coolers
31-01-2015 8:21 PM
My son uses this stuff: http://www.overclockers.co.uk/showproduct.php?prodid=TH-005-CL liquid metal alloy thermal paste to improve the performance of his cooler.
Re: CPU Coolers
31-01-2015 11:10 PM
also depends if you doing overclocking
Re: CPU Coolers
01-02-2015 12:32 PM
Erm.... I'm skint
Looks like good paste, I use artic silver as a rule it's always served me well.
@rontw Thanks for the wisdom. No I'm not over-clocking(well just a little shall we say), I just need the cpu temps to be in check. I upgraded 1 of 2 pc's last year (both the same spec) which I built in 2011. I'm just getting ready for the summer early. The Matterhorn is a pretty radical cooler for what I need which has 6 heat pipes, the Pure Rock only has 4, but as you say, German... which to me = properly done! in this kind of field anyway. (The bo proper 'English Version' would be too expensive). Just to note, the matterhorn keeps the cpu @30C (Old one 50C+) ticking over @500rpm. 50C+ on a warm day was to hot for my liking on tickover. Now the other machine is starting to run hotter even after cleaning and re-seating the cpu the summer is just a little to much for the stock cooler.
Re: CPU Coolers
01-02-2015 1:21 PM
http://www.scan.co.uk/products/silverstone-he01-heligon-cpu-cooler-6-heat-pipes-and-140mm-silent-fan...
I did have to buy a bigger case though to fit it in as I couldn't get the side on with my previous case, it is huge.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-123-NX&groupid=2362&catid=35
Re: CPU Coolers
01-02-2015 1:55 PM
I've bought it now £21.59 from a scanshot, I'll update the post when I've installed it. Decent review
Re: CPU Coolers
02-02-2015 1:01 PM
Under load when rendering videos the CPU was hitting 70+C since installing the above cooler it never goes above 58C.
Forum Moderator and Customer
Re: CPU Coolers
03-02-2015 1:16 PM
So I'll be a little bit happier about fitting this new Pure Rock cooler which looks a little smaller/lighter like the Hyper 212 Evo that you have.
Re: CPU Coolers
03-02-2015 1:29 PM
Look forward to hearing how you get ion with yours.
Re: CPU Coolers
03-02-2015 4:08 PM
to be honest though it was worth the effort with the hyperevo unit, took my average temp in use from 60+ under load to under 50 so well worth swapping out the previous cooler, once I changed the fans over to noiseless units its even better (the standard fans were to noisy for my liking)
Re: CPU Coolers
03-02-2015 5:31 PM
But the H60 is easier to fit
Re: CPU Coolers
04-02-2015 1:28 PM
As you can see it was a very tight fit but apart from that it went in very easy. Nice and quiet, all I can hear now is the coil whine from the psu
Looks good too.
