CD R/W and BIOS problem
- CD R/W and BIOS problem
- « Previous
- 1
- 2
- Next »
Re: CD R/W and BIOS problem
18-10-2011 1:24 PM
The situation now is I only have access to one of these test beds. The BIOS on this one doesn't see the CD Drive (I'm sure it did in the early days of this problem), but if I boot up from a floppy, and then insert a CD into the CD Drive, I can see the contents of the CD (using the DIR command). However, if I use a bootable CD (a Windows XP CD) just to test the server, the server just goes straight past the CD drive to the point where it says "No Operating System Found".
Regards
19-10-2011 11:44 AM
I have just discovered that if I go into BIOS, the bit that lists Primary and Secondary Masters and Slaves (where you normally see the hard drive and the CD Drive listed), it doesn't mention the slim CD Drive, but if I put a CD in the slim CD drive, reboot and go into BIOS, it says CD-ROM at the Primary Slave position. Remove the CD, and reboot, and the BIOS list goes back to nothing found. I don't have any hard drives connected at the moment - when they are connected, they will connect via a RAID Controller daughterboard (and to save you asking - yes they were connected via the daughterboard but I removed the daughterboard yesterday, so I know they aren't affecting the BIOS list or the non-ability to boot from a CD).
Regards
19-10-2011 12:19 PM
Do you know what firmware your drives have ?
20-10-2011 5:25 PM
I have gone to the web as you suggested, and found that a lot of these web-sites look a bit iffy (to me at least).
I haven't used it for a few years, but there used to be a site for getting old drivers from. They didn't charge a fee, and I could get the driver as an uninstalled file that I could copy and move to the machine that I want the driver on. Today, all the sites seem to insist on doing a scan of my pc so they can update all my drivers if necessary. I cannot think of a better way to get 'nasties' on my pc than doing that. I don't want to do that on my pc at home, and I definitely don't want to get any nasties on my pc at work, being linked to loads of others through the company network.
Are there any reliable, safe sources of this software?
20-10-2011 5:36 PM
20-10-2011 9:11 PM
Thanks for the suggestion
20-10-2011 10:16 PM
Note: I have not used the above file but it's from a reputable source.
The driver download sites can be a right pain... you just need to know the right link to click on to get through to the actual file.
20-10-2011 10:28 PM
21-10-2011 3:02 PM
The easiest way is to boot to a 'Live' Ubuntu USB stick, then go the "Disk Utility" and that will tell you
21-10-2011 9:07 PM
Thanks for all of your help
- « Previous
- 1
- 2
- Next »
