CD Autostart
gleneagles
Aspiring Legend
Fixes: 17
CD Autostart
Seem to have installed something on my computer which is preventing CD/DVDs from auto running but I can't remember how to switch this back on.
Other problem is that external drive is not coming on automatically... easy enough to activate these things using windows explorer but I would rather just switch the auto run back on.
We are born into history and history is born into us.
6 REPLIES 6
HairyMcbiker
All Star
Fixes: 21
Re: CD Autostart
Assuming XP.
Open Regedit
locate
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionpolicies
delete the NoDriveTypeAutoRun value
gleneagles
Aspiring Legend
Fixes: 17
Re: CD Autostart
Thanks for that but I am only half way there.
The external drive now loads up fine but the internal cd/dvd still refuses to auto start disks.
Oldjim
Resting Legend
Fixes: 63
Re: CD Autostart
This tells you how to disable it - logically reverse the process http://support.microsoft.com/KB/126025
shutter
Fixes: 65
Re: CD Autostart
Digging a bit further on that linky..... (check out the column on the right hand side of the page) I found this
• The AutoRun feature or the AutoPlay feature does not work when you ...
(330135) - Explains why a CD-ROM may not start to play automatically when you insert it in your CD-ROM drive. Provides a step-by-step resolution.
http://support.microsoft.com/kb/330135/en-us
gleneagles
Aspiring Legend
Fixes: 17
Re: CD Autostart
All sorted now via the microsoft help page,
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
1. Double-click Autorun and see whether a zero or a one is displayed in the Value data box.
o If the value for Autorun is 1, go to step 5.
o If the value for Autorun is 0, right-click Autorun, and then click Modify. In the Value data box, type 1, and then click OK.
2. Locate and then click the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
3. Double-click NoDriveTypeAutoRun to see its value. If the value is 0xb5, the AutoRun feature for CD-ROMs is turned off. To turn on the AutoRun feature, follow these steps:
a. Right-click NoDriveTypeAutoRun.
b. Click Modify.
c. In the Value data box, type 91.
d. Select Hexadecimal, and then click OK.
Exit Registry Editor.
Thanks for your responses
VileReynard
Fixes: 20
Re: CD Autostart
And some would say that Linux is hard. Grin Grin Grin
