CCleaner
CCleaner
How come CCleaner is so much faster than any other of its type, taking only a few seconds to scan and clean (or so it seems) compared to something like Reg Clean that takes many times longer, and then won't deal with the results unless its registered. Or maybe I'm missing something in CC's setup perhaps? Or, I think its doing something that its not actually. It gets a lot of recommendations, and, its free, but is it any good?
1 REPLY
Re: CCleaner
I've had CCleaner on my PC for a long time and always been pleased with it.  You're right it is quick. So many of the others scan your system and as you say want paying before they clean it up for you.
