CCleaner and removables
Luzern
All Star
Can CCleaner be used to clean removable drives. If it can how has it to be set up?
Does anyone know, please.?
MrT
Re: CCleaner and removables
Based on CCleaner v3.00.1303
Start CCleaner
Click on Tools Tab
Click on Drive Wiper
Select type of Wipe and Security
Tick box for removable drive. Make sure no other Drive box is ticked!
Click Wipe
Use with Great Care!!  Smiley
Luzern
All Star
Thanks Smiley
use with great care
is that a general comment. or emphasized for removables? Any particular aspect?
MrT
Just a gentle reminder - just to be careful that you don't wipe you C drive by mistake. Can't be too careful.  Smiley
Fixes: 9
Can you wipe an active drive ?
Seemed to remember I kept getting the message the Active drive could not be formatted or perhaps I am getting confused between wiping and formatting a drive ?
Denzil
Quote from: lucerne
When you say "clean", do you mean wipe completely or just get rid of rubbish? You can just clear out the rubbish by going to Options - Include, then Add and browse to the drive concerned.
Luzern
All Star
Accumulation of files emptied from the recycle bbins
