CCTV Required
- CCTV Required
CCTV Required
07-08-2017 10:24 PM
Sadly we feel it's time to get cctv but we have no idea what to get.
Requirements:
Budget £500
10 Meter Distance to observable object:
Mount point under eaves:
Cable preferred:
Must work well after dark:
For external use:
2 cameras required:
I don't care if it's bulky:
Sound Optional:
No great need to monitor online:
Thoughts please
Re: CCTV Required
08-08-2017 7:31 AM - edited 08-08-2017 8:07 AM
Try these cameras
http://www.hikvision.com/us/Products_1_10508_i7593.html
Very good night vision.
I bought it with this NVR
http://www.hikvision.co.uk/Products_accessries_212_i32196.html
Add a hard drive you need approx 1Tb per camera is what I was advised, this model supports H265 encoding, but the cameras are only H264+ so you could purchase a cheaper NVR.
It's a one wire install, the cameras and NVR are PoE.
Re: CCTV Required
08-08-2017 11:26 AM
I'll take a mooch at those, thanks for your Wisdom.
