CCTV - P2P ???
- CCTV - P2P ???
CCTV - P2P ???
21-11-2016 6:09 PM
Hi y'all
Recently joined Plusnet for Broadband, using their wifi router which seems to be quite good for signal strength.
Anyway, I have also recently had CCTV installed which is fully setup to be viewed through any tv in the house and directly connected into the router for viewing on my smart phone when out and about.
The app needed to view on my smart phone is set up and can view the cctv but only when within the range of my wifi router. If I'm out and about the app/phone cant connect or view the cctv.
Spoke to the tech guy who installed and he said I need P2P forwarding and a static Address, No idea what where or how I get these so any help would be fantastic. I'm not really up to speed with techie lingo so could someone explain what I need to do simply.
Thanks guys!
Re: CCTV - P2P ???
21-11-2016 6:27 PM
you will also need a static IP address from plusnet if you want to be able to actually connect to it (it'll cost you £5) - if you don't want to pay that then you'll need a DynDNS provider.
Re: CCTV - P2P ???
21-11-2016 8:09 PM
Update...
Got a static IP Address from Plusnet.
Checked Broadband firewall in my account / members centre to which its turned off.
So all being well I should now be able to view the CCTV (when the tech guy comes back later this week)
Re: CCTV - P2P ???
21-11-2016 8:22 PM
Re: CCTV - P2P ???
21-11-2016 8:37 PM
See I told you I'm not much with tech haha
Can I change this setting myself or do I need to speck with plusnet team to open ports?
Re: CCTV - P2P ???
21-11-2016 8:40 PM
Re: CCTV - P2P ???
21-11-2016 8:41 PM
Thanks for the info
Ill let you know how I get on.
Re: CCTV - P2P ???
22-11-2016 4:00 PM
Trying to port forward on my router, typed in the router address which brings me to the plusnet connection status screen where there's buttons for settings.
I can click on the buttons but nothing happens and can not type in my router password to gain access.
Have I missed anything? Help please
