CCGI not processing timthumb.php script
mitchrenton
Hi Guys, not sure if this is something that anybody has experience with but my script timthumb.php is not working and therefor not rendering images on my website http://ccgi.hitech.plus.com/ You can see the site there.  I have all the permissions set correctly but still no good. Does anybody have any idea why this isn't working?
1 REPLY
Fixes: 162
Re:CCGI not processing timthumb.php script
Are you directly referencing the folder the images are in and is that folder set with the correct permissions?
 Chris Parr
 Plusnet Staff
