CA VMN Toolbar
- CA VMN Toolbar
CA VMN Toolbar
23-06-2010 11:40 AM
Much to my surprise it installed itself with no action from me. Kaspersky did not flag it up and neither did IE or user account control in W7.
I disabled the addon and used Revo to uninstall. Rebooted and it was still there so had another go and this time Revo picked up registry keys so I deleted those and did a CCleaner clear up of files and registry.
I have changed the association and they now open with FF and no problem. Am just scanning with Kaspersky and Malwarebytes and nothing has shown up so far. Question is, can anyone explain how come it installed itself so easily? I don't usually use IE but is there anything else that I could have done to prevent this happening?
I understand from googling that it is not spyware.
Re: CA VMN Toolbar
23-06-2010 1:13 PM
Still, some applications just don't give you the choice. The installer has to have rights to install itself, so it can use those same rights to install add-ons in Firefox.
Comodo have a thing called Defence Plus, which comes with their security package, and I think can be installed on its own. This monitors everything that tries to install, or directly access memory, or access important system files, and asks you if you want to allow them. It is a bit intrusive, though, and I turned mine off as it was asking stuff all the time.
Now if you had been using Linux and not Windows... [runs and hides ;D]
Re: CA VMN Toolbar
23-06-2010 3:44 PM
It was odd though because each time I clicked on one of them, it displayed but crashed IE. This happened just a few times then it didn't crash but installed the toolbar instead.
I still can't get my head around how something like this can get past my security so easily, particularly the user account control. It's rather worrying TBH.
Re: CA VMN Toolbar
23-06-2010 4:14 PM
Quote from: poppy It was odd though because each time I clicked on one of them, it displayed but crashed IE. This happened just a few times then it didn't crash but installed the toolbar instead.
This is indicative of a page exploiting a security vulnerability to install software, such as toolbars, without prompting the user.
IE is the largest target for these, and it really does show that just *visiting* a website can infect your computer with any type of nasty malware/virus.
B.
Re: CA VMN Toolbar
23-06-2010 4:59 PM
It would seem that the problem had nothing to do with them but was due to security of the browser. I haven't downloaded anything other than Windows updates this morning.
I think that maybe I should use my Ubuntu lappy more for Internet.
Is there anything else that I should do security-wise other than not use IE? I thought that Kaspersky was up to the mark but now not so sure.
Re: CA VMN Toolbar
23-06-2010 6:14 PM
However take the results with a pinch of salt because what Kaspersky finds is sometimes an old copy of an application that has already been updated.
Re: CA VMN Toolbar
23-06-2010 6:26 PM
It showed up Flash, Foxit and Irfanview as needing to be updated so have done this.
Also the autorun function so have fixed those.
All that is left is on the attachment and it seems that there is no need to fix these.
Hopefully, won't have the problem again but will steer well clear of IE.
Re: CA VMN Toolbar
23-06-2010 7:08 PM
Re: CA VMN Toolbar
23-06-2010 7:20 PM
Here's one which is quite apt for some of our more excitable members:
Re: CA VMN Toolbar
25-06-2010 1:13 PM
Quote from: poppy Is there anything else that I should do security-wise other than not use IE? I thought that Kaspersky was up to the mark but now not so sure.
Hide or delete the icon that starts IE.
Tell your friend to use Firefox.
