C Drive
SEXTON250
C Drive
My Crive is almost full and I would like to move items to the Drive
Can anyone help
Fixes: 10
Re: C Drive
Something to try first:
If you have been rigorously applying Windows updates a huge amount of the space could be taken up with the uninstall files for all the updates. Try http://www.tech-pro.net/windows-update-remover.html - I remove anything older than 1 month on the basis that if I haven't needed to uninstall it by then it's unlikely I ever will.
Have you identified what you want to move?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 19
Re: C Drive
Kindly note.... this is for XP only...
Fixes: 62
Re: C Drive
Where is your "My Documents" Folder
Fixes: 25
Re: C Drive
If you have Windows Vista or 7 you can use Windows Disk Management to:
  • Shrink your D: drive (I'm assuming you meant you have one)
  • Create a new partition at the end of the disc
  • Copy the contents of your D: drive to the new partition
  • Delete the D: drive
  • Expand the C: drive into the space created
This gives you a bigger C: drive so you don't have to worry.
Fixes: 62
Re: C Drive
But make sure that you have all your documents and data backed up first
Fixes: 25
Re: C Drive
It's always a wise precaution to have everything backed-up but I have never experienced a problem with Windows Disc Management, except that it sometimes isn't prepared to shrink a partition very much.  On the other hand, I have sometimes had problems with other disc repartitioning software.
