Buying a new monitor
- Buying a new monitor
23-02-2008 3:21 AM
Re: Buying a new monitor
23-02-2008 9:21 AM
Personally I prefer non-widescreen aesthetically and at present pricing is such that you get more area for your money and it takes up less desk space. My 1280*1024 LCD (which is of course 5*4 not 4*3 so even squarer) cost about £100 from DABS and suits me fine.
Software like Outlook is using multiple panes horizontally, but that just conveniently leaves a bit of space above or below for "odds and sods".
And IE is filling up with toolbars (or can do) so again vertical space is under pressure.
23-02-2008 9:39 AM
23-02-2008 9:50 AM
Quote from: Samson I calculate that to get the same screen area I would need a 19" widescreen, and to get the same screen height I would need a 21" or 22". Any comments, observations, experiences, recommendations etc. will be gratefully read. Thanks.
Just by coincidence, I changed from a 17" CRT to a 19" Widescreen just a week ago. After just having done some measurements, I feel that your calculations are a bit out (if you don't mind me saying so).
17" CRT:
Diagonal = 15.75"
Width = 12.5"
Height = 9.5"
19" Widescreen:
Diagonal = 19"
Width = 16.25"
Height = 10"
For me, it's the extra width of the widescreen that I like most of all and, as you can see from the measurements, there's a slight gain in the physical height of the screen.
Hope this helps
Regards .....
23-02-2008 10:07 AM
16" diagonal, 13" wide, 9.5" high. That's the visible window with it on.
They'll all vary a bit of course.
23-02-2008 10:26 AM
23-02-2008 10:47 AM
Regards .....
23-02-2008 11:52 AM
23-02-2008 9:57 PM
I tend to think widescreens are often sold as a marketing ploy. To most people, 19" widescreen sounds bigger, but is. of course, smaller in area, and hence cheaper to make, than a 4:3.
23-02-2008 10:30 PM
Quote from: Denzil a widescreen leads to a lot of scrolling up and down
That's why I like my 19" 1280*1024, it's 12" tall visible, i.e. taller than A4.
(and 15" wide, which is 2 A4 page widths after removing the normal margins.)
23-02-2008 11:09 PM
23-02-2008 11:12 PM
24-02-2008 12:50 AM
It was used to run an aquarium screensaver
25-02-2008 9:26 AM
25-02-2008 9:31 AM
