Bulk rename file utilities
- Re: Bulk rename file utilities
05-08-2009 10:27 AM
I know that Win XP does it - but it annoyingly adds a space and then puts the number between brackets - and I've long been told NOT to have spaces in website file names.
I've done the normal google search and there seem a large number of utilities available
But can anyone please recommend one that they have found good to use and reliable.
ta
Mal
05-08-2009 10:44 AM
05-08-2009 11:11 AM
http://www.irfanview.com/
05-08-2009 11:20 AM
05-08-2009 11:49 AM
Quote from: Whiffler IrfanView will do a batch rename of image files but having not used that facility I'm not certain what it does with the file names, but it's free
You specify what filename format you want when batch renaming.
That would rename your chosen images 'renamed_image001.jpg', 'renamed_image002.jpg', 'renamed_image003.jpg' etc.
Works pretty well.
05-08-2009 11:59 AM
I normally do it manually - but I've been sent about 200 photos to put online !
- all at the correct size so no need to put through Photoshop.
Mal
05-08-2009 12:05 PM
05-08-2009 12:09 PM
05-08-2009 12:44 PM
but I'll give IrfanView a go too .
M
05-08-2009 5:01 PM
05-08-2009 5:04 PM
In fact I'm going to install IrfanView on the "office" laptop as that has no image processing other than the very basic Vista program !.
M
05-08-2009 6:40 PM
you set the size in OPTIONS, and the destination folder (make it a sub folder of original) and you just drag and drop the files on it.... the resized files have the size added to the original file name, and are in the subfolder "Resized"....
Very Fast, and Very good
Oh yes, Irfanview, is good for batch re-name.... (can`t remember if it will do batch re-size)
05-08-2009 11:25 PM
Quote from: shutter Oh yes, Irfanview, is good for batch re-name.... (can`t remember if it will do batch re-size)
Yes, it will.
12-08-2009 6:23 PM
