Bulk rename file utilities
mal0z
I often have to rename groups of files - actually images for use on websites.
I know that Win XP does it - but it annoyingly adds a space and then puts the number between brackets - and I've long been told NOT to have spaces in website file names.
I've done the normal google search and there seem a large number of utilities available
But can anyone please recommend one that they have found good to use and reliable.
ta
Mal
13 REPLIES 13
Njal
Re: Bulk rename file utilities
Cliff_Jordan
IrfanView will do a batch rename of image files but having not used that facility I'm not certain what it does with the file names, but it's free
http://www.irfanview.com/
pierre_pierre
this does every thing you want and more - it is free, use it regularly http://www.freecommander.com/
bobpullen
Fixes: 316
Quote from: Whiffler
You specify what filename format you want when batch renaming.
That would rename your chosen images 'renamed_image001.jpg', 'renamed_image002.jpg', 'renamed_image003.jpg' etc.
Works pretty well.
mal0z
Many thanks - that gives me a few to try.
I normally do it manually - but I've been sent about 200 photos to put online !
- all at the correct size so no need to put through Photoshop.
Mal
pierre_pierre
you can resize easily with IrfanView and that cost a lot less than Photoshop - its FREE
Strat
Fixes: 565
Thanks for the Freecommander link Pierre Smiley
mal0z
Yes I know P-P, but I have a licence for Photoshop from way back,
but I'll give IrfanView a go too .
M
pierre_pierre
And I have a legal copy of Paintshop pro, but prefer Irfan for some jobs
mal0z
Indeed - I tried it as well as the one you recommended.
In fact I'm going to install IrfanView on the "office"  laptop as that has no image processing other than the very basic Vista program !.
M
shutter
Fixes: 65
If you need to resize pics, search out Fast Image Resizer..... (by Adionsoft)
you set the size in OPTIONS, and the destination folder (make it a sub folder of original) and you just drag and drop the files on it.... the resized files have the size added to the original file name, and are in the subfolder "Resized"....
Very Fast, and Very good
Oh yes,  Irfanview, is good for batch re-name.... (can`t remember if it will do batch re-size)
bobpullen
Fixes: 316
Quote from: shutter
Yes, it will.
The_10th
Great little program Irfanview. Have used it for years and far better than what M$ ships with its products.
