Bubble Struugle !
- Re: Bubble Struugle !
Bubble Struugle !
28-10-2008 10:35 PM
(Preferably without disabling flash as a lot of educational software needs it)
28-10-2008 11:16 PM
29-10-2008 9:22 AM
Alternatively, if you can't share that info for security or whatever, FYI :- this seems to be the most easily distributed flash I have come accross in a long time. The main website openly offers a link to download the actual .swf file, which meens that any industrious students could just fling it on a disk/usb drive and play it off that.
good luck on this one, I hope your running an AD server.
29-10-2008 9:29 AM
I remember my days at high school, when we had a choice of windows 3, or windows 3.1 on the network. In Windows 3.1 the games were all disabled during lessons, but if you knew where to look you could run the Windows 3 version of Soliter in Windows 3.1 and could get around it!
Phil
29-10-2008 12:44 PM
29-10-2008 3:05 PM
Quote from: me ...it's one of a myriad of variants on an old game...
Pang! FTW!!!!
30-10-2008 8:22 AM
You are trying to access restricted content. This violation has been logged and the Deputy Head sent an email. If this violation is serious or repeated, then your tutor and parents will be informed.
Of course, if you're working in 21st Century Edukation, then you may not have the kit to do this. Or a Deputy Head who is a total psycho.
Good luck :
30-10-2008 9:38 AM
Effectivly your solution would work best if the restriction was locked into the browser settings of every terminal in the school, so that even if the file was opend from a local instance, the browser would refuse to load it. Hence why an AD server would be grossly prefferable, it makes rolling out network wide settings changes slightly less time consuming.
