Bt hh 5 trying to use on plusnet
- Re: Bt hh 5 trying to use on plusnet
06-12-2014 1:22 PM
Hi all really need help here came over to plusnet from bt but having trouble with the router (when on ps3 nothing else will work wirelessly) so wanting to use my bt home hub 5 read on line it can be done but can't get mine to work any help would be great thanks all
4 REPLIES 4
06-12-2014 1:34 PM
06-12-2014 1:50 PM
That the site I used but can't get it to work
06-12-2014 2:02 PM
fibre or adsl
06-12-2014 3:40 PM
I was using a HH5 until recently.
1st do a factory reset on it.
2nd setup as OTHER isp
3rd enter your username@plusdsl.net & password in the boxes.
That should be it.
That should be it.
