Bt Vision box
Thatmanagain
Bt Vision box
i have been told that the vision box will not work as a standalone digibox for freeview.
Is it true and do I need to sell it on and invest in a separate box?
Any suggestions for a reasonably priced digi type recorder.
Cheers
1 REPLY
Thatmanagain
Re: Bt Vision box
Job sorted!
Yes!! you  can "hack" into these boxes and re chip them and install other software..but not for the amateur!! Undecided
Got one of these
HUMAX PVR-9150T 160gb
on ebay yesterday for 50quid Smiley
Onwards and upwards.
