Bt Sport login error
- Bt Sport login error
22-11-2018 6:27 PM
I am able to login via other devices.
Can anyone advise a solution please?
Thanks!
Re: Bt Sport login error
24-11-2018 8:00 AM
Moderators Note
This topic has been moved from Everything Else to Tech Help
24-11-2018 8:05 AM
Error is related to username / password:
“ID001”
Error Message: Sorry, we didn't recognise the details you've entered (Username or/and Password); Please check and try again. Or, if you need a reminder of your username or password, please use the links provided
Not sure on the Mojo, but it if doesn't have all the google services installed - which I guess it doesn't as you haven't installed this from play store - then maybe it's missing an authentication piece.
