Broadband usage not showing
- Broadband usage not showing
25-11-2016 8:52 AM
I started using Plusnet on Tuesday, my usage showed as 15.36GB on Tuesday (seems high, as I did no streaming)
Then 443.06MB Wednesday (seems low as I did stream a couple of programs)
Then 0KB Yesterday (I was using my PCs all day)
Does this just not work? It seems all over the place
Re: Broadband usage not showing
25-11-2016 12:10 PM
Mine is the same.
Sometimes only 5GB, sometimes 5MB, sometimes 5kB
29-11-2016 11:07 AM - edited 29-11-2016 11:08 AM
Well it looks like mine has stopped registering altogether
30-11-2016 6:46 PM
You're lucky to get that much! Mine's merely been showing this for at least two days:
Sorry, there's nothing to show at the moment.
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 4 hours for your usage to show up - please try again later.
If you have any questions about your usage, please see our View My Broadband Usage FAQ or contact our Support Team.
30-11-2016 6:51 PM
01-12-2016 4:22 PM
But Plusnet doesn't listen.
And so it ends...
01-12-2016 7:44 PM
Mines been reading zero for about a week now.....................
09-01-2017 5:15 PM
I like to record usage. I did once ask if there could be an option to make it available as a .csv file.
However for the last few months the screen version has been continually showing the message below.
Looking through the forum this seems to be an ongoing problem. What's the status on this
09-01-2017 10:10 PM
Ditto.
It's still showing this.
09-01-2017 10:15 PM
Why does it say 4 hours when the "feature" has been disabled.
Idle sods can't even be bothered to correct their web page.
24-01-2017 8:50 AM
24-01-2017 8:53 AM
24-01-2017 11:20 AM
They don't have a ETA of their next problem.
They are not even bothering to fix their current problems.
