Broadband speed
- Broadband speed
Broadband speed
15-02-2009 3:07 PM
Today 15:01 1217 kbps (152kB/s) 313 kbps (39.1kB/s) Share
Today 15:00 1592 kbps (199kB/s) 275 kbps (34.4kB/s) Share
Not a problem, just curious.
Up to a month ago it never got above 1000 kbps so it's certainly improved, has it something to do with additional servers PN has recently installed.
Re: Broadband speed
15-02-2009 4:25 PM
Re: Broadband speed
16-02-2009 2:23 PM
Sorry, don't know how to find my router speeds.
Re: Broadband speed
16-02-2009 2:27 PM
Re: Broadband speed
16-02-2009 2:28 PM
Its all normal and just a snap shot in time
Re: Broadband speed
16-02-2009 3:17 PM
I Have a standard Thompson router (supplied by PN) Although it can be used as a wireless router I use a wired setup.
Re: Broadband speed
16-02-2009 3:35 PM
Re: Broadband speed
16-02-2009 3:38 PM
[url=http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0]Speedtouch[/url]
I can't guess what you intended either. Unless that is the default IP of one of those routers (seems a little strange).
Re: Broadband speed
16-02-2009 3:41 PM
Re: Broadband speed
16-02-2009 3:45 PM
@gleneagles - your router's web interface should have a page somewhere which gives you the line statistics - sync rate up and down, line attenuation and noise margin. Don't worry if you don't understand the numbers. We do :), so it might give us a clue as to whether you are seeing normal fluctuation or if there is a problem.
Re: Broadband speed
17-02-2009 10:56 AM
A user name and password are being requested by http://192.168.1.254. The site says: "Thomson Gateway"
Only thing is my plusnet password & user name do not seem to work so what user name & password is it looking for ?
The router was set up automatically so I did not need to use any password when setting it up.
Re: Broadband speed
17-02-2009 10:59 AM
Default User Name = Administrator , Password = blank
Re: Broadband speed
17-02-2009 11:01 AM
Otherwise, if you do a factory reset on your router, it will be:
username: admin
password: admin
You'll need to reconfigure the router though.
Re: Broadband speed
17-02-2009 11:13 AM
Re: Broadband speed
17-02-2009 11:13 AM
Call it a security enhancement.
